IRs purchased from Helix store in Powercab?
amsdenj
I purchased a bunch of Ownhammer IRs from the Helix store. I find these can't be loaded into Powercab because it has no way to login to check for a license. Is there another way? If not, will this eventually be supported?
Another issue I noticed is that on MacOS, I can only import 48 kHx 24 bit IRs. I get an error with 32bit IRs that says they must be 16, 24 or 32 bit. Anyone else noticed this?
I had alot if issues with 32 bit IRs as well. I found a free online converter and converted them to 32 bit wav files and then they worked fine. I don't understand why that is. IR info says they are 32 bit before the conversion process. Nonetheless they have all worked for me after converting them.
  • 4 weeks later...
