Mikkymillion Posted January 21, 2019 Share Posted January 21, 2019 Brief story: I got line 6 pod xt live and tried firmware ware update with all current versions of line6 softwares. Everything worked well until I was asked to switch the pedal off/on....then boom! <Invalid Error Code 02> The hustle: I followed all the pieces of advice on this issue....safe mode, press this press that, smash it on the floor....*thats actually not part of it*; send it to the Line6 I.T. guys.... None of them is around my country. At some point I encountered using midi cables and read all I could, bought several cheap midi USB cables to no avail.... And to crown it all, I dropped a support ticket and the best option I got was to get a replacement...*smh* I can go on and on to tell you how bad it felt, but I'm here to tell you how I got it resolved. SOLUTION After two months with a dead pod, I finally invested in a midi USB cable that's a bit expensive *ROLAND UM one MK2*...ever encountered it? Well, that's what I used; I flashed the 3.1 with anxiety but ended up happy. The cable works. So if u are like the former me, get the cable and flash with all drivers needed. #P.S. I'm posting this so that no one will waste so much time, energy and effort it took me to figure this out. 1 Quote Link to comment Share on other sites More sharing options...
cbrillow Posted January 21, 2019 Share Posted January 21, 2019 6 hours ago, Mikkymillion said: #P.S. I'm posting this so that no one will waste so much time, energy and effort it took me to figure this out. Don't know that I'll ever have a use for this, but I applaud your effort and consideration for others who may run into the same issue. Good job! Quote Link to comment Share on other sites More sharing options...
Tinyfireball Posted January 22, 2019 Share Posted January 22, 2019 Quote Link to comment Share on other sites More sharing options...
