Latency HD 500
lewandowskip
Yes it is annoying and many use a dedicated interface.
What you could do is record the track(s) in your DAW and lower the fader on that channel(s) until it is bearable or nil, in most DAWs you can just not activate the listen button just the record. You monitor befor it hits the PC along with any other tracks or metronome from the PC. Set as low a buffer as possible.
Or just send the channels output to a dummy not used output that is not going to the master bus and back into the HD.
