lewandowskip Posted January 27, 2019 Share Posted January 27, 2019 Hi, I have a little latency on my POD HD 500. I hear it when i play through my PC and even when I play directly to the phones. Latency appear when I play guitar and when I try record anything through micropohone. I used my POD HD 500 about year ago and then worked Ok. Could you help me? Quote Link to comment Share on other sites More sharing options...
bjnette Posted January 28, 2019 Share Posted January 28, 2019 Yes it is annoying and many use a dedicated interface. What you could do is record the track(s) in your DAW and lower the fader on that channel(s) until it is bearable or nil, in most DAWs you can just not activate the listen button just the record. You monitor befor it hits the PC along with any other tracks or metronome from the PC. Set as low a buffer as possible. Or just send the channels output to a dummy not used output that is not going to the master bus and back into the HD. Quote Link to comment Share on other sites More sharing options...
