How to properly connect an external pedal to be used with a Pod Hd500x
ldgante
Im fairly new to this and wanted an advise from the experts. I just bought a Boss overdrive that would like to use along with my POD HD500x but have no idea how to set it up (where do I plug it on my POD?). I've been searching the web but can't seem to find a tutorial or instructions. Any help will be much appreciated.
Thank you
There is "fx loop" or something similar named in the effect block list. Place this block in your chain where you want your overdrive to take place. Then, connect the physical pedal to the pod with the effect loop in/out ports. (Not 100% since I don't own any pedals, but should get you started.)
