adiaz7531
G10 causing slight noise into recording interface
Hello!
I see that when using the G10 in a recording setup/DAW there is a visible amount of “noise” being displayed by the audio channel’s LEDs.
Just to check I replaced the G10 with an instrument cable and the “noise” was gone.
Is this inherent in this device or is there troubleshooting I need to do?
Thanks!
How are you powering the g10?  Are you using a USB port on your computer?  That will introduce noise. Use a separate usb power supply for it.
