Controlling 6 blocks from three stomps on HX stomp
Danishbacon
I've tried looking for a solution to this but am having a hard time. Is there some kind of mode that allows three stomp to be set to three individual blocks and then scroll to another three blocks. Not sure how to best explain this.
Stomp 1 - tuner
Stomp 2 - filter
Stomp 3 - od
Stomp 1a - reverb
Stomp 2a - delay
Stomp 3a - looper
By pressing something the mode toggles from Stomp to Stomp A - hope that makes sense.
Thanks
Stomp 1 - tuner
Stomp 2 - filter
Stomp 3 - od
Stomp 1a - reverb
Stomp 2a - delay
Stomp 3a - looper
Thanks
Well kind of. The tuner is not a block so that kind of mucks it up.
For blocks, the easiest way is to assign two blocks to one footswitch, but have one block engaged and the other disengaged. Then when you stomp it switches between them.
Another way, my favorite way, is to set up snapshots.
With HX Stomp, use an external tuner to free up the FS3 unless you also want to have a tap tempo. I don’t bother with HX stomp tap tempo as in many cases its not that necessary.
Leave the reverb on all the time, then you don’t need a footswitch for that. You can often do that for delay too.
That leaves two footswitches for effects, and one for looper.
