hx effects 6 switch looper bug
wahwahferrar
Hi,. If I hit record, then 'once' the loop will play once, and left bottom screen says 'overdub OUT', however, it does record overdubs.
If I then hit 'once' again, the screens all display the same, but no overdubbing occurs (as expected).
This a problem for me as I wish to record a loop, then press 'once' and immediately start playing over the top, with out overdubbing.
I believe this is a bug - overdubbing should only occur when the leftmost screen says 'overdub IN'
Thanks
