Sign in to follow this
stevenjsmith
Using Patches as part of a signal chain
Hi everyone,
I've had my Helix LT a while now (about 9 months).  Absolutely love it but don't get to spend as much time discovering what it can fully do as much as I would like.  I've downloaded some patches from Glenn DeLaune and there's a few really great ones, in particular is the Cornford amp one.  I love the fully overdriven sound but need a clean sounds to go with it.  Ideally I'd like a 2 amp setup -  clean amp and switch to the Cornford patch for the dirty sounds.  What is the best way to go about this?  Can the entire patch for the Cornford be set to one part of the signal chain?  I've messed around with A/B setups with a clean and and dirt one and then other effects but I really want to get the Cornford in there somewhere.  Apologies if this has already been asked elsewhere but I've searched and cannot find anything.  Thanks in advance for any help/suggestions.
With snapshots you can change amp settings or even change the amp.  Snapshot 1 could be your Cornford chain and then Snapshot 2 could be the Jazz Chorus.
Thanks.  I've never used snapshots other than the ones that were already part of the patches i purchased/downloaded.  I'll have a look into that option.  Thanks again.
Thank you for your support Sir. Yes if you use Snapshots you can get the clean sound I have programmed in this video. It starts with the Clean Snapshot 1 here:
Go into your Global Settings>Footswtiches and set the settings like in this picture:
52144348_2233654973513703_89704087280922
Thanks Glenn, that's great.  I'm a big fan of your work and music. Thanks
Also, I'm looking at buying the clean amp bundle that you've put together.  If I wanted to is it possible to use one of those for clean sounds and the cornford patch for dirty on the same preset?
you would have to totally re-program the patch for that and I don't think the Helix has the DSP power to do that.
Create an account
Register a new account
Sign in
Sign In Now
