rampig59
G10 system charging issue
I have not used my Relay G10 for several months and now when the system is plugged in for charging, the base flashes RED and so does the transmitter.
After a few minutes the transmitter changes to a flashing GREEN and then goes back to flashing RED.
If I remove the transmitter from the base, the base flashes WHITE and there is NO LIGHT on the transmitter.
My software has the latest update installed.
HELP!!
I have the same problem. My receiver flashes red and transmitter nothing at all. I was able to ise it ince only and then nothing.
Same problem me too ....  RED the transmitter and Red or Nothing the receiver .... I tried also to update the firmware .. but nothing happen ..
This is just a guess, but somebody above mentioned the unit hadn't been used for several months...rechargeable batteries don't like that. Once they're dead long enough, they won't take a charge anymore. Try it with an old cell phone, tablet, ipod, etc.... or leave a vehicle sitting for an extended period without a trickle charger hooked up. At some point, there's no resurrecting them.
Hi everyone ..
I solved !! ..
I have downgrade the transmitter to version  1.03, I previous updated to 1.04 ..
now it's working again ....
hope this work with you ..
thank you Tobiak
i have the G10  and used both updates and it works
On 5/15/2019 at 12:02 PM, tobiak said:
Hi everyone ..
I solved !! ..
After I have updated, my transmitter stopped charging. Tried to revert back to the old firmware but it the software cannot detect my transmitter.
