Natedog_37 Posted November 27, 2013 Share Posted November 27, 2013 Ok I have all me settings setup to be about the same volume for the most part. I have the volume setup to give me 100% so I have full control. I move the master Volume to maybe 25% at shows we get it set to what is a good mix and go from there. I turn the amp off between sets. Come back for set 2 turn amp on, Master Volume is the same but the amp is 15% louders? Other issue I am seeing is you move the volume a hair and it is loud as hell!!! more it a hair down and you can't hear it. get to about 50% and the volume sounds the same get to 100% and you can't tell it is much different than 50% Why is this. You would think the volume would have a equal sweep all the way up to 100% but that 100% is not the case. I have been thinking of limiting the volume to say 30% and see what it does. Anyone have this issue. Quote Link to comment Share on other sites More sharing options...
strange_eye71 Posted November 28, 2013 Share Posted November 28, 2013 yes I have experienced exactly the same issue with the master volume. My workaround was to set the channel volume a little lower to pull the master volume past the 3 o'clock ( where I have the most problems with the master volume knob) seems to work better. Good Luck. 1 Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted December 2, 2013 Share Posted December 2, 2013 Don't set your channel volume to 100%. The combined total volume is going to be the same - you will notice if you have your channel volume at 100% that when you turn the master volume past a certain point it does not get any louder - you've already reached the maximum amp output. Instead set your patch channel volumes so that when you change patches the volume is where you want it to be, irrespective of where the master volume is set. Then use master volume to adjust the sound based on the overall loudness you need for the place you are playing. 1 Quote Link to comment Share on other sites More sharing options...
Natedog_37 Posted December 5, 2013 Author Share Posted December 5, 2013 Ah I will give that a try. I was guessing the 100% was the issue. But found it strange getting use to the settings. Quote Link to comment Share on other sites More sharing options...
gabeberco Posted December 30, 2017 Share Posted December 30, 2017 On my spider 450 watt amp 4 six seven years and I am still having issues with my master volume it's always been a problem but it's worth now Quote Link to comment Share on other sites More sharing options...
