Is The Firmware Update V2.0 Necessary If Using An Hd500 With The Amp?
davemorgan
Hi - Is the Firmware update v2.0 necessary if using an HD500 with the DT25 amp? I don't want the expense of MIDI cables and the extra work involved if I get everything through the HD 500 anyway. Cheers.
Not necessary, but is worth it in my opinion just for those times you want to play somewhere and not bring an extension cord for your Pod and all that jazz. Load the amps you want into the DT and grab and go. Heck, buy a cable at guitar center, update it and pick your 8 amps, and then return the cable.
