Sign in to follow this
doloo
Garageband and logic pro x stop responding after select Helix Native as plug-in
I'm using Helix Native 1.71 on trial. It works fine for the first time. The next day when i choose Helix Native as plug-in in Garageband or Logic Pro x, both program stopped working( not responding, after 10 mins waiting, had to force quit ), as shown in screenshots.
Having same problem here. It's also happening in Reaper. last week they were both fine running it :/
That also happens to me whenever I don't have internet and I open Helix Native.
Thanks to you im able get native to function. Had switch wifi off, load plug in. once loaded and not crashed switch internet back on. thanks
I have never had any problems with Helix Native running in Logic Pro X. Running Mac OS 10.14.3, Logic Pro X 10.4.4, using a Focuswrite Saffire Pro 40 Firewire audio interface through an OWC Thunderbolt 3 doc.
Same problem here.
I bought Reaper and Helix native. Reaper crashes when I want to use  "Helix Native".
I've opened a support ticket. But maybe there exist an advice here.
23 hours ago, schuha_at said:
Same problem here.
There is a whole area of these forums dedicated to Helix Native.
While you are waiting for a reply to your support request, you may wish to check this thread to see if it helps solve your problem.
Hope this helps.
I got advice from the Line 6 Support to uninstall the Helix native and install again. I registered the native during the new installing.
The second advice was to do the same with reaper, but this was not necessary anymore.
Now it works fine on my desktop
Shut off your wifi before opening your DAW (Logic for me). Open a Helix plugin on a track.  It forces a Line 6 prompt for your Login and PW, fill out the info then turn wifi back on before pressing Enter,  then it works
