mbonde
How to stop all midi messages when I change presets
I have a setup where the Helix LT controls a Beatbuddy (drummachine) and a Boomrang looper through midi. When I change presets on the Helix the Beatbuddy automatically changes to the right song. It works really well, until today.
I would like to be able to change guitars during a song. Playing the acoustic while singing, and then change to the electric for a solo. The problem is that when I change preset during a song, the Helix sends out a midi command that changes the drum beat on the Beatbuddy. I have removed all midi messages from command center. When I change to an empty preset I have the same problem.
So my question is this. How do I make sure that the Helix does not send any midi messages, when I change presets?
I've got a powercab so i use the midi section to change my speaker modeling per preset or snapshot.
What you tell is really strange, if you change preset without sending a midi order, nothing would happened....This is the case with the PC+, i stay on the same speaker....
Have you saved your preset after removing midi message in command center ?
I don't understand why you have the same problem in an empty preset...
Go to Global Settings>MIDI/Tempo and set PC Send to Off. That will make it so the PC messages associated with each preset are sent automatically when you change presets.
Ho yes, i've read that but i've never met the problem.....
Thanks for the replies. I made a new preset from scratch and now it works. There must have been some kind of bug in the old one.
