Helix with Moog EP-3
jcspirited
Recently got a Moog EP-3 expression peddle to us with my helix. I thought it was a  ordinary expression peddle, I guess not. It has a sellecter switch on the bottom. With the sellect swtch in “stander” , it sweeps from minimum to max back to minimum. With the select switch in “other” it sweeps from max in the heal position, minimum it the toe position. Dose anyone have any dealings with a Moog EP-3, or any useful input.
The two most common issues are that pedals with TRS connectors don't work. Needs to be just TR, and the potentiometer needs to be 10Kohm. I can't find what the potentiometer is for the Moog but the pictures I'm finding show a TRS cable, which doesn't work with the Helix. You may need to do some soldering. I saw it has a polarity switch on it. Maybe that'll help with the TRS issue.
So true, when I opened the box and saw the TRS cable, I was not happy. I can’t find a use manual for it. I should have sent the $125.00 for a mission, and it looks like I’m going.
Thanks brue58ski and ELChivo0414
I got it to work with the switch in “other” and reverse the minimum and maximum on the helix.
