Moving the fixed Compressor!
Pacemaker1000
On 3/6/2019 at 7:11 AM, Pacemaker1000 said:
Usual position for a Compressor is before the amp.
Please can this be made 'movable ' in an update?
True, and this is a good idea  . . . BUT you can also select a compressor block instead of a distortion block block (boost + EQ, red compressor, blue compressor, blue compressor treb, vetta comp, and the vetta juice).
This won't work if you are wanting to apply a compressor to a distortion block, but it's still good to keep in mind since often you don't need a compressor if you're using a distortion block.
