IcaroPaiva
How Can I Use Inputs On Ux2 Without Pod Farm Open?
I cannot find a way to use my input channels on the UX2 to record without having to open te POD Farm and I really do not want to use the POD Farm because I already have my tone presets and it changes them.
Can anyone give me some help please?
Thank you!
Make sure that you are using the UX2 ASIO sends to record.  You will not need to have POD Farm open, and you will record dry.  That simple.
I have the same problem. I have mixcraft and the only way to use the UX2 is via podfarm. I cannot find a way to access the UX2's mixer controls in order to switch between inputs on the UX2...contrary to the expert answer, it is NOT simple...
Have you configured mix craft to use the UX2 and it's ASIO driver as the audio recording and playback device? If so, I believe you should be able to select either of the UX2 inputs as the Source Input when arming and recording a track in mixcraft.
you have to go into the line6 control panel applet to change the inputs.
Where would I find that control panel?
In the windows control panel with all the other control panel applets. I think it's called line 6 audio midi.
Hit the "Windows" button or open the start menu and then type in the search bar "Line" you should see "Line 6 midi" as an option to select.
mid.jpg?psid=1
  • Downvote 1
I had the same problem on my mac with my line 6 ux2...Search in spotlight (line6 midi) and then go to (recording) and map there if you want (line1-2 on instrument or mic) as input.and then go to logic and there you are.
