surfsup1955 Posted March 12, 2019 Share Posted March 12, 2019 Helix clearly has the ability to assign Guitar In-Z as a parameter within Snapshots but it won't actually support assigning various Ohm values to different Snapshots. It only allows for the same Ohm value across all 8 Snapshots - or at least on the unit I own. Was just curious if this is even do-able? Quote Link to comment Share on other sites More sharing options...
surfsup1955 Posted March 14, 2019 Author Share Posted March 14, 2019 Going once... Going twice??? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 14, 2019 Share Posted March 14, 2019 On 3/12/2019 at 2:50 PM, surfsup1955 said: Helix clearly has the ability to assign Guitar In-Z as a parameter within Snapshots but it won't actually support assigning various Ohm values to different Snapshots. It only allows for the same Ohm value across all 8 Snapshots - or at least on the unit I own. Was just curious if this is even do-able? Yes, you can do that. You just have to assign the Input Z parameter to a snapshot controller, just like you would any other parameter you want to change with snapshots. Quote Link to comment Share on other sites More sharing options...
surfsup1955 Posted March 14, 2019 Author Share Posted March 14, 2019 28 minutes ago, phil_m said: Yes, you can do that. You just have to assign the Input Z parameter to a snapshot controller, just like you would any other parameter you want to change with snapshots. Appreciate it Phil. I've been using snapshots since they were introduced and once I got wrapped around the concept, I basically haven't had any issues assigning parameters and their values - and yes, doing it just as you described above! I love snapshots and depend on 'em in a big way! Your reply caused me to dive in a bit more. It appears I actually can assign them via the knobs on my floor unit (something I never do) but not via my Helix Editor. I'm running version 2.71 on the editor and 2.71 on the machine, which I believe are up to date. If it wouldn't be too much to ask, would you verify if you're able to tweak a few snapshots with various Ohm assignments via your editor and verify if they feed to your machine? Thx! Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 14, 2019 Share Posted March 14, 2019 1 hour ago, surfsup1955 said: Appreciate it Phil. I've been using snapshots since they were introduced and once I got wrapped around the concept, I basically haven't had any issues assigning parameters and their values - and yes, doing it just as you described above! I love snapshots and depend on 'em in a big way! Your reply caused me to dive in a bit more. It appears I actually can assign them via the knobs on my floor unit (something I never do) but not via my Helix Editor. I'm running version 2.71 on the editor and 2.71 on the machine, which I believe are up to date. If it wouldn't be too much to ask, would you verify if you're able to tweak a few snapshots with various Ohm assignments via your editor and verify if they feed to your machine? Thx! Now that I think about this, I do remember this being a bug with HX Edit. It will on the unit itself, though, as you said. Quote Link to comment Share on other sites More sharing options...
surfsup1955 Posted March 15, 2019 Author Share Posted March 15, 2019 Ah, ok. No need to submit a bug report then. Thanks again. Quote Link to comment Share on other sites More sharing options...
