jordimbrinkman
Helix + Powercab 112 plus - how to get great basic sounds
Hi all,
Since a month I own the Helix Floor + Powercab 112 plus (and the Relay G10S). A great compact setup! I'm impressed by its versatility, all options and ease of use. Before I had a traditional setup: Custom Audio tube pre-amp, mesa 20/20 power amp, TC G-system, Mesa cabinet. Top class sound, but I was tyred of carrying it around... So I made the big switch to modeling.
As said I am very impressed, however I am struggling to get my basic sounds right (for which I'm reaching out for help): clean, crunch, rock and high-gain. I know my traditional tube setup is quite a benchmark, but still hoping to get my sounds close to what I'm used to. I kind of miss that punchy/crispy sound, especially when I play with my (rock) band my sound has no clear definition (missing the 'balls').
I really want my setup to work and don't want to give up as I am convinced about the benefits of the Helix. So I was thinking:
- to keep tweaking till it's right (it must be me)
- try a tube combo amp instead of the powercab
- lower my expectations
- get help through this forum :-)
I go for the last option as I know there are so many happy and experienced Helix users out there.
So, here is my question:  did any of you go through the same process with satisfying results in the end? Any tips how to get that great basic authentic sound right (which I appreciate is a vague question)? See my current setup/ settings below.
Thanks a lot for sharing any experience/advice! Much appreciated!
Main guitar: Fender Strat with single pick ups
Powercab: Vintage ( sounds most pleasing to me for the few amps I use from clean to high gain)
Clean: Solo Lead Clean (amp only, no cab from Helix)
Crunch: clean channel above + Screamer
Overdrive: Mandarín 80 (amp only, no cab from Helix)
Lead: Placater Dirty (amp only, no cab from Helix)
On top of above amps (on which I made minor tweaks to most pleasing sound), I experimented by adding EQs, compressors and effects.
Create an account
Register a new account
Sign in
Sign In Now
