Linkccr23 Posted April 15, 2019 Share Posted April 15, 2019 Not sure why but when I use the 4 cable method with my Cornford mk502 my amp selector won’t work anymore. It’s such a bummer. I really was hoping to be able to use this with my Cornford for effects and such. Any help would be greatly appreciated!? Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 15, 2019 Share Posted April 15, 2019 It sounds like you need to put an FX Loop block in your Helix preset. Without that, the 4 cable method won’t work correctly. Quote Link to comment Share on other sites More sharing options...
Linkccr23 Posted April 15, 2019 Author Share Posted April 15, 2019 I do have that now, I can finally use it but the problem is when I go to use the amp channel selector footswitch it wont work. For some reason it won’t change the channels. It has this weird 6 pin connector. Has a center pin which I am guessing Is for power. Wish I could figure out how to use it with this amp. But even when I hook up the separate footswitch my channels won’t change, either I have to pick one channel from the amp and use the fx loop switch to bypass the amps preamp to get a clean sound or manually change, it’s so strange Quote Link to comment Share on other sites More sharing options...
