Cghoward Posted April 19, 2019 Share Posted April 19, 2019 After setting up the four cable method, the helix and amp sound great together, but I only get a response from stomps I have placed before the send channel. For example, the volume pedal/comps sound good. However, when I try to add delay or reverb after the return stomp, I get no delay or reverb. I also tried using the 4CM template patch, but I got the same results. Any thoughts on how to solve this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 19, 2019 Share Posted April 19, 2019 Are you sure the Return block is activated in the preset? 1 Quote Link to comment Share on other sites More sharing options...
jpdennis Posted April 19, 2019 Share Posted April 19, 2019 Well, basic question I need to ask; What is the amplifier? And show your cabling; I am not saying you got it wrong though I did the first few times. When I use the 4CM it is with one of my Mesas which have series send/return effects loop circuits and haven't had an issue with the 4CM once I understood the cabling. Dennis Quote Link to comment Share on other sites More sharing options...
jpdennis Posted April 19, 2019 Share Posted April 19, 2019 1 minute ago, silverhead said: Are you sure the FX Loop (or Send/Return) block is activated in the preset? Great point! Quote Link to comment Share on other sites More sharing options...
