Sign in to follow this
Cghoward
4CM ISSUE: stomps after return signal are not working
After setting up the four cable method, the helix and amp sound great together, but I only get a response from stomps I have placed before the send channel. For example, the volume pedal/comps sound good. However, when I try to add delay or reverb after the return stomp, I get no delay or reverb.
I also tried using the 4CM template patch, but I got the same results. Any thoughts on how to solve this?
Are you sure the Return block is activated in the preset?
Well, basic question I need to ask;
What is the amplifier?  And show your cabling; I am not saying you got it wrong though I did the first few times.  When I use the 4CM it is with one of my Mesas which have series send/return effects loop circuits and haven't had an issue with the 4CM once I understood the cabling.
Dennis
1 minute ago, silverhead said:
Are you sure the FX Loop (or Send/Return) block is activated in the preset?
Great point!
