ChrisWitoski Posted April 21, 2019 Share Posted April 21, 2019 does anyone know if its possible to keep a loop playing and use the tuner? this would help live gigs tremendously but i can't figure out how help! cw Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 21, 2019 Share Posted April 21, 2019 No, it’s not possible. Quote Link to comment Share on other sites More sharing options...
ChrisWitoski Posted April 21, 2019 Author Share Posted April 21, 2019 damn,. maybe something they will address in a future update, thanks for the reply :) Quote Link to comment Share on other sites More sharing options...
soundog Posted April 22, 2019 Share Posted April 22, 2019 why not take use an Out block after the looper, and then use the In for an input to the tuner can't imagine why you'd want to do this, but the world if full of wonders Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 26, 2019 Share Posted April 26, 2019 Sounds like an external tuner might be the best solution, at least for now. Once you engage the Helix tuner you can use the 'Output' parameter to send the signal via for example one of the Helix Send outputs to an external tuner of your choosing. That method allows you to continue using the Helix's tuner switch to determine when to send signal to your external tuner. Using the Helix's tuner routing means you don't have to do something tedious like include a Send block in every preset. It also means your tuner is only engaged when you hit the switch on the Helix so no extra cables and external tuner between your guitar and your amp/FRFR as would be the case if you hooked up an external tuner before or after the Helix. Quote Link to comment Share on other sites More sharing options...
