Sacrifice82 Posted May 2, 2019 Share Posted May 2, 2019 Hey all! I have a problem with my Pod HD500X. Im trying to connect my pod with a computer using a usb cable. But my system doesnt recognize the device.It shows that something is connected to computer by usb cable but device is not recognized. Same problem with Pod HD500X Edit. It looks like device is not connected but its connected. Cable is good. Could it be something with an usb port in Pod? Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 2, 2019 Share Posted May 2, 2019 Did you try a different USB port on the computer ? Quote Link to comment Share on other sites More sharing options...
blekenbleu Posted May 2, 2019 Share Posted May 2, 2019 3 hours ago, Sacrifice82 said: It shows that something is connected to computer by usb cable but device is not recognized. Since Windows 10 reports >>something<< connected, the USB cable is probably OK. Not recognizing the device typically means the driver is missing; download it from Windows HD500X driver Version 4.2.7.6 Released 8/21/15 Quote Link to comment Share on other sites More sharing options...
Sacrifice82 Posted May 2, 2019 Author Share Posted May 2, 2019 I did download the driver. My friend told me that it can be chip broken. I had an accident while cable was connected to computer. I dont how to write correctly but when i touched m computer short circuit happened. Had to buy chipset, procesor and ram memory. I think the same happened to my Pod. I did check different usb ports. Even checked on 2 more computers. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 3, 2019 Share Posted May 3, 2019 Whoa, I think you need to explain in more detail what happened. Sounds like everything got zapped. Quote Link to comment Share on other sites More sharing options...
