Slooky 4 Posted December 22, 2013 Almost impossible to get a good chorus sound out of the HD500. So what I did is buy a Chorus Pedal, works awesome! :lol: :lol: :lol: :lol: :lol: :lol: 1 Quote Share this post Link to post Share on other sites
Metalchef 55 Posted December 22, 2013 I have found the chorus mods in the 500 very useful. Where in the chain were you using it. I have found that placement with certain effects is everything. Quote Share this post Link to post Share on other sites
boyce89976 18 Posted December 22, 2013 ^ Agreed. I have had good success getting everything from a nice subtle chorus, to a really deep, thick chorus. Depending on the patch I'll place it either before or after the amp block to get the desired sound. 1 Quote Share this post Link to post Share on other sites
guilhordas 14 Posted December 22, 2013 the best chorus on pod is pitch glide Quote Share this post Link to post Share on other sites
Slooky 4 Posted December 22, 2013 I have placed it before and after, just can't seem to get that lush chorus sound. I've also tried the pitch glide too. Michael Landau -Andy Summers,Çharlie Burchill some of the great chrorus sounds. Can't make it happen on the pod! Quote Share this post Link to post Share on other sites
Metalchef 55 Posted December 22, 2013 Which Chorus pedal and Where are u running it in the chain? Strictly just curiousity. I always like to here people's takes on adding exterior effects. That is a true test of versatility for me. Did line 6 make their gear compatible not only with line 6 equipment but my many other effects pedals as well. Quote Share this post Link to post Share on other sites
DeanDinosaur 224 Posted December 22, 2013 Here's trick to get the analog chorus sounding good. Move the tone control all the way to the left. It will make the sound a little darker but you can compensate with the amp treble or presence. 1 Quote Share this post Link to post Share on other sites
DeanDinosaur 224 Posted December 22, 2013 Here, try this and tell me if it sounds better or worse than the real corus you bought. I personally think it's my favorite corus patch that I've made so far. http://line6.com/customtone/tone/256768/ Quote Share this post Link to post Share on other sites
boyce89976 18 Posted December 23, 2013 I've made that Andy Summers tone and it sounds good... Very close to the tone from "Every Breath You Take". He uses a flanger in the video... When I feel like I need a more aggressive chorus, I've used a light flanger to good effect. Quote Share this post Link to post Share on other sites
gckelloch 23 Posted December 23, 2013 I agree that is probably a matter of tweaking. Chorus is probably one of the easier things to model accurately. The delay and modulation aspect of the sound is elementary. Modern simulations of "bucket brigade" filtering should be nearly identical to the actual pedals, but it is the more complex aspect to simulate. Quote Share this post Link to post Share on other sites
radatats 921 Posted December 23, 2013 Dimension is a DSP hog but it can sure sound sweet when set up right... Turn all 4 switches on and play with the mix... Quote Share this post Link to post Share on other sites
boyce89976 18 Posted December 23, 2013 Dimension is a DSP hog but it can sure sound sweet when set up right... Turn all 4 switches on and play with the mix... Played with Dimension a little tonight, and you're right. Still need to fiddle with it a little bit, but I was easily able to get a good result with it. Quote Share this post Link to post Share on other sites
Slooky 4 Posted December 23, 2013 Thanks for all the suggestions! I will try these tonight. Quote Share this post Link to post Share on other sites
edstar1960 385 Posted December 23, 2013 Here's trick to get the analog chorus sounding good. Move the tone control all the way to the left. It will make the sound a little darker but you can compensate with the amp treble or presence. Thanks! I tried this and it really gives a much fuller sound. :) 1 Quote Share this post Link to post Share on other sites
DeanDinosaur 224 Posted December 23, 2013 Thanks! I tried this and it really gives a much fuller sound. :) My pleasure, Glad to hear that. :) Quote Share this post Link to post Share on other sites
gckelloch 23 Posted December 24, 2013 I guess whatever works works -- keep in mind that if you roll off highs with one effect and then boost them back up with another, you are boosting noise and loosing some signal definition. Such is the premise of using a low capacitance cable with passive PUP's to pass highs to the amp in the first place...but yes, rolling off highs before the amp produces less preamp distortion hash. Amp section distortion character can be controlled with the tone stack knobs -- if the DEP Master knob is up high enough. Boosting the midrange and cutting treble and presence can produce a nice creamy sustain. Not sure that's what you want for this type of sound, but it's something to consider. Quote Share this post Link to post Share on other sites
ftuller 12 Posted December 27, 2013 I was messing around with the pitch glide to comment on another thread and found that the pitch glide at the front of the chain, 50% mix, +0.1, gave a nice chorus tone (at least to my ears). I generally don't use the chorus for what I play but I added in the analog chorus to compare it to the pitch glide at +0.1 and thought the pitch glide sounded better. Quote Share this post Link to post Share on other sites
SiCantwell 12 Posted December 29, 2013 I like Dimension with Switch 1, adding Switch 4 sometimes. Quote Share this post Link to post Share on other sites
Slooky 4 Posted January 1, 2014 Which Chorus pedal and Where are u running it in the chain? Strictly just curiousity. I always like to here people's takes on adding exterior effects. That is a true test of versatility for me. Did line 6 make their gear compatible not only with line 6 equipment but my many other effects pedals as well. I run it this way Guitar-Chorus pedal-Pod hd 500. I use the Danelectro Cool Cat chorus. This pedal is the best sounding chorus pedal. I really can't believe how good it really is! Nothing on the pod 500 comes even close! Quote Share this post Link to post Share on other sites
NinoScholz 17 Posted January 2, 2014 I run it this way Guitar-Chorus pedal-Pod hd 500. I use the Danelectro Cool Cat chorus. This pedal is the best sounding chorus pedal. I really can't believe how good it really is! Nothing on the pod 500 comes even close! Man i used to use their $15 FAB chorus - the little blue plastic box - still one of the best choruses i've used. The controls were great - the mix knob worked beautifully. no tone suck - what more do you need? Hell they even threw in a pedal bag for the $15 asking price. Quote Share this post Link to post Share on other sites
