cgtrox Posted May 19, 2019 Share Posted May 19, 2019 Is it doable without using ANOTHER external box? Quote Link to comment Share on other sites More sharing options...
Cody_smith Posted May 20, 2019 Share Posted May 20, 2019 If the amp has a midi input then probably. If it does not have a midi input then no. What is the amp? Quote Link to comment Share on other sites More sharing options...
cgtrox Posted May 20, 2019 Author Share Posted May 20, 2019 It's a 50W EVH 5150 III head and it does have a MIDI jack. Just got the HX Effects yesterday and was just wondering if anyone else has done anything similar with a 3 channel amp Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 20, 2019 Share Posted May 20, 2019 From the 5150III manual: To set up and use MIDI for channel selection: 1. Press both channel SELECT buttons {E and I} simultaneously to enter MIDI "Learning Mode." The current amp channel LED will start to blink. 2. Send any desired Program Change message on any desired channel from your MIDI controller to the amp. The amp channel 1 LED will start to blink unless you have previously assigned that Program Change message to a different amp channel, in which case the previously assigned channel LED will start to blink. 3. Select the target amp channel (1, 2 or 3) using the channel SELECT buttons {E or I}. All three amp channel LEDs will briefly illuminate to indicate if the amp channel assignment has been changed for the Program Change message sent (if the amp channel assignment has not changed, which would be the case when assigning amp channel 1 to a Program Change message for the very first time, the three amp channel LEDs will not all illuminate briefly because the amp channel assignment has not changed from the default amp channel 1 assignment). If the Program Change message is currently assigned to amp channel 1 (default), you will have to press channel SELECT {E} twice to select amp channel 2. If the Program Change message is currently assigned to amp channel 2, you will have to press channel SELECT {E} twice to select amp channel 1. 4. Repeat steps 2–3 for each channel on the amp, if desired. You can also assign multiple Program Change messages to the same amp channel for more flexibility. You can use the Footswitch to temporarily change channels at any time during MIDI set up and it will have no effect on saving the amp channel assignments. All channel assignment changes must be made using the front panel channel SELECT buttons {E and I}. 5. Once you are done setting up MIDI Program Changes, press both channel SELECT buttons {E and I} simultaneously to exit "Learning Mode." The amp is now set up to switch to the target channels whenever the selected Program Change messages are sent on the selected MIDI channel. The default MIDI channel for the amp is channel 1. You can change the MIDI channel for the amp by sending a Program Change message from any other desired MIDI channel during Learning Mode. The amp will then only respond to Program Change messages and Control Change messages on that new MIDI channel. _____________________________________________________________________________________________________________________________________ There ya go. Go into Command Center, set the switches to the MIDI commands that you want to use, then follow the directions above. Of course, you'll have to set the switches in Command Center on EVERY preset in which you require this functionality. That's why a third box is a better idea, UNLESS the idea is to match a specific effects configuration for each channel, which just requires setting one Instant Command vs three stomps. Still have to do it for each preset, but easier and doesn't waste the stomp buttons. Quote Link to comment Share on other sites More sharing options...
cgtrox Posted May 20, 2019 Author Share Posted May 20, 2019 Wow, thanks bro! I'll try it tomorrow, GOT is on, LOL!! Quote Link to comment Share on other sites More sharing options...
