spanishmartin Posted May 20, 2019 Share Posted May 20, 2019 Hi. I've just reinstalled podfarm 2 after a lengthy break. I have a toneport di but I only want to use it as a dongle. I should be able to use the 1814 for podfarm standalone right? I did purchase a podfarm 2 license. Thanks. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted May 21, 2019 Share Posted May 21, 2019 Yes. As long as the device is plugged in and you're logged in to license manager. Quote Link to comment Share on other sites More sharing options...
spanishmartin Posted May 22, 2019 Author Share Posted May 22, 2019 Thanks Gaz. That's good to know. Now I need to investigate why it's not working. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 30, 2019 Share Posted May 30, 2019 POD Farm standalone only works with other USB audio interfaces if you purchased a hardware independent license. You could try inserting an instance of the PF2 plug-in (using the Toneport as a dongle) in you DAW and just feed it the signal form your 1814, but depending on your computer there may be noticeable latency. Also, I don’t think a Firewire interface is supported with the hardware independent license. BTW, did you upgrade to PF2? The Toneports were typically PF1 where as the POD Studios are PF2. Quote Link to comment Share on other sites More sharing options...
spanishmartin Posted June 9, 2019 Author Share Posted June 9, 2019 Thanks Triryche. Not for the first time you have given me the right answer, and sorry for the late reply. The thing is I contacted support some time ago, clearly stating that I was using a firewire interface. I've been going backwards and forwards trying out their suggestions but off course, none of them were ever going work. I actually discovered this myself just before I saw your post only minutes ago. I read it in one of the podfarm 2 download notes. I don't use a Daw, but I will try a vst host. If that doesn't work, I will just forget about podfarm. I already have much better sounding amp sims that work perfectly in standalone with the Maudio firewire interface. I only wanted to use podfarm for the Bass amps. I seem to remember the bass amps sounding pretty good, and I don't have many bass options in my current amp sims. Yes you are right about my podfarm 2. It was an upgrade. when I first got the toneport, it came with gearbox gold. Cheers. Quote Link to comment Share on other sites More sharing options...
