rocktube38 Posted May 25, 2019 Share Posted May 25, 2019 My friend on bass own a G10, I own a G10 for my guitar, and last week, on stage, my guitar was played in the bass amp !! It's the first time, we didn't had any problem before. Someone can telle us what is the problem, please ? Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 25, 2019 Share Posted May 25, 2019 Both of your transmitters were using the same channel. It's a little tricky with the G10 since, unlike the G10S, there's no way to manual select the channel you want to use. You can still use multiple G10 systems on the same stage, but you have to make sure you go through the automatic channel selection process with each one. So one of you should plug his transmitter into its receiver and wait about 15 seconds for the receiver to find the best channel (the transmitter blinks when ready). Take that transmitter out - it's set. After that, so the same process with the second transmitter and receiver. The receiver will select a different channel than the first one because the second will receiver will see that as interference. Take that transmitter out, and you'll be all set. The key is to not plug the transmitters back into the receivers again. If you do, you'll have to do this process again. Quote Link to comment Share on other sites More sharing options...
