Just Bought A 500x And Want To Put A Blood Red Jtv On Order....
milesargall
The whole dream rig thing. If the sounds really are that good, and not clinical, it really is a cool setup.
Imagine going from thick and heavy drop d for everlong to 12 string for crazy little thing called love to stratty cold shot goodness..... And the amp and guitar all talking to each other.....
Anyway; talking SRV - how did he use the two amp thing? And what's the feature of the 500?
Do I have it right that he ran two amps; one clean and one dirty???
And can you run two cabs in stereo (with a DT25) using the HD in 2 amp mode and have one running 'amp1' and the other as 'amp2'?
Cheers.
while it is true you can't go stereo with the DT you can certainly use the dual amp function.  As stated above though, the DT power section will only sync up to the amp in Path A.  You also cannot turn the amps off to switch so you have to be creative with either dual volume pedals or use the exp pedal to morph between the amps.  Here is a patch to show you what I mean.
http://line6.com/customtone/tone/256843/
"The whole dream rig thing. If the sounds really are that good, and not clinical, it really is a cool setup.
Imagine going from thick and heavy drop d for everlong to 12 string for crazy little thing called love to stratty cold shot goodness..... And the amp and guitar all talking to each other....."
Hey Miles ~ Been a JTV69 HD500 owner for a few years now and I will say it's more fun than a trip to Disney !!
