PlayinOcean Posted May 27, 2019 Share Posted May 27, 2019 Hi all, Been tinkering around with the snapshots on my HX Effects. I'm trying to set one snapshot to 1/4 delay, one shapshot to 1/8 dotted and one to a fixed 320 ms delay. However, once I change the 1 button on my third snapshot to set a time instead of a subset (1/4, 1/8 etc), my other snapshots also change to a fixed time instead of the values I assigned to them. Am I doing something wrong? If so: please explain to me how I should do it. Quote Link to comment Share on other sites More sharing options...
Etienne73 Posted May 27, 2019 Share Posted May 27, 2019 Hi :-) I have a HX Stomp. Found out how it's been done on my device yesterday. I had to assign controller by snapshots. Delay time (fix) and delay note sync parameters. Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 27, 2019 Share Posted May 27, 2019 1 hour ago, PlayinOcean said: once I change the 1 button on my third snapshot to set a time instead of a subset (1/4, 1/8 etc), my other snapshots also change to a fixed time instead of the values I assigned to them. It's an odd limitation, but you cannot change from fixed value (ms) to subdivision value (1/4, 1/8, etc...) with a snapshot. There are features requests on ideascale for this if you want to vote it up... https://line6.ideascale.com/a/dtd/Delay-Time-Per-Snapshot-to-include-subdivisions-AND-ms-option/896687-23508 56 minutes ago, Etienne73 said: I have a HX Stomp. Found out how it's been done on my device yesterday. I had to assign controller by snapshots. Delay time (fix) and delay note sync parameters. Are you saying that you found a way to do change the fixed time to subdivision time in a snapshot? If so, please share. Quote Link to comment Share on other sites More sharing options...
Etienne73 Posted May 27, 2019 Share Posted May 27, 2019 28 minutes ago, codamedia said: Are you saying that you found a way to do change the fixed time to subdivision time in a snapshot? If so, please share. I thought but I didn't. :-( Everything looks logical in HX Edit and device Firmware 2.71. But note sync is either on or off for all snapshots with 1 delay block. I have to use 2 delay blocks in 1 preset as a workaround. 1 delay block for note sync applications and 1 delay block for fix delay times in ms. Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 27, 2019 Share Posted May 27, 2019 17 minutes ago, Etienne73 said: I thought but I didn't. :-( Everything looks logical in HX Edit and device Firmware 2.71. But note sync is either on or off for all snapshots with 1 delay block. It does seem like a very odd limitation of the HX devices. I'm sure there is a reason you can't change that from a snapshot, but it would sure be great if you could. IIRC.... not only can't you change from MS to Subdivision, you can't even change from one Subdivision to another. I have an LT with 3 delay blocks. One for slap (fixed ms), one for tap tempo set to 1/8 or 1/4 (I don't remember) and yet another to manage my dotted 8th syncopated delays. Such a waste... because I could have done all of that with one delay if snapshots could control the subdivision settings. Quote Link to comment Share on other sites More sharing options...
Etienne73 Posted May 27, 2019 Share Posted May 27, 2019 I'm not sure how helpful but I found a workaround with 1 delay block. If I change tempo settings to snapshots and set BPM 125 fix for snapshot 3 I get a 320ms delay at 1/4 Triplet note sync. https://www.dropbox.com/s/jtp38dgo3g6ikos/Helix 3 different delay times per 1 block.mov?dl=0 I made the step by step video above for explanation. Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 28, 2019 Share Posted May 28, 2019 On 5/27/2019 at 8:05 AM, Etienne73 said: I'm not sure how helpful but I found a workaround with 1 delay block. If I change tempo settings to snapshots and set BPM 125 fix for snapshot 3 I get a 320ms delay at 1/4 Triplet note sync. Yes - this is a common work around for the problem. I prefer to keep my tempo set to GLOBAL so I could make it fit my work flow, but it certainly is a good solution for those that can. Quote Link to comment Share on other sites More sharing options...
Etienne73 Posted May 28, 2019 Share Posted May 28, 2019 On 5/27/2019 at 2:22 PM, codamedia said: ... you can't even change from one Subdivision to another ... ... if snapshots could control the subdivision settings ... Here on my HX Stomp (FW 2.71) it's possible with 1 delay block to have 3 different subdivision snapshots. 8 minutes ago, codamedia said: Yes - this is a common work around for the problem. I prefer to keep my tempo set to GLOBAL so I could make it fit my work flow, but it certainly is a good solution for those that can. So you say it all depends if someone wants to use the tap tempo feature? If yes, this workaround isn't a good choice, right? Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 28, 2019 Share Posted May 28, 2019 5 hours ago, Etienne73 said: Here on my HX Stomp (FW 2.71) it's possible with 1 delay block to have 3 different subdivision snapshots. Yes you are correct.... I just revisited that myself and see that it is possible. It makes me wonder why I chose to insert a 3rd delay for my syncopated delays though? I must have been too lazy to setup the parameters that day - LOL! Quote Link to comment Share on other sites More sharing options...
