Sign in to follow this
jlklein
POD Series Encoder jump?
Hi folks,
So, a question on the POD series, and maybe they even fixed this with the POD HD series...I have a POD X3 Live that I bought used a couple years ago based on Lincoln Brewster's use and endorsement of the line, and I do like the sound of this thing quite a bit. However, one thing I really hate about it is that if I recall a patch and then go to adjust any of the physical knobs, the patch setting suddenly jumps to the current knob position as soon as I move it rather than allowing me to adjust it from it's currently saved setting. For example, if I want to tweak up the reverb a bit on a dry-ish sounding patch, and the physical Reverb knob is way up for whatever reason, as soon as I move the Reverb knob I'm suddenly playing in Shea stadium. Or, if my patch volume needs adjusting and I grab the Tone Volume knob, I may get a sudden blast of volume as soon as I move it if the knob is physically up high.
Did the POD HD series and/or Helix series finally figure out how to fix this? I was looking at some used HD500's as I've gotten into looping, but I won't bother if they haven't fixed that issue. If the Helix fixed it, I'll hold out for one of those maybe.
Thanks,
Jeff
The HD units still do it (as mentioned). But if you use the EDIT program, you can make the minute adjustments.
It doesn't help for live tweaking. But is a "fix".
Could be worse -
I played devices where you had to take the expression pedal to 0 or 128 before it would be able to make changes.
