trueinsider Posted December 28, 2013 Share Posted December 28, 2013 I just picked up my first guitar and this amp, so I basically know nothing yet. I enabled tuner mode and tuned low E string (Crunch and Metal LED lit up both perfectly). Then I tuned A string (perfectly too). Then I go back to low E to check it just in case and now Clean LED lit up. Why? I haven't touched it at all. If I tune that again, then A will be shown as wrong. I dont understand. Quote Link to comment Share on other sites More sharing options...
NBell Posted December 29, 2013 Share Posted December 29, 2013 Hey trueinsider, Was the Clean flashing? The tuner will always look for notes that correspond to the standard guitar string tunings (EADGBE). Crunch and Metal (Channel B & C) indicates the string is in pitch. If one of the string is a little flat from being in tune the Clean will flash. When Channel A (clean) is lit it is indicating the note is 20 cents flat, Channel B (Crunch) indicates 5 cents, Channels B & C (Crunch & Metal) indicates the note is in tune. Channels C and D is the same concept, except indicating higher pitch. 2 Quote Link to comment Share on other sites More sharing options...
