wwwwwv Posted June 4, 2019 Share Posted June 4, 2019 Quote Link to comment Share on other sites More sharing options...
zolko60 Posted June 7, 2019 Share Posted June 7, 2019 Monitored signal should be the same as recorded. The only difference can be the volume. The recorded (monitored) volume depends on your track faders, master fader, Hx trim setting. You can compare them by switching direct monitoring to DAW monitoring while playing (I know - 37ms latency is painful) 10-15dB of headroom is normal in case of "amplified" signal - you can still adjust it in Helix blocks. 20-30dB of headroom is normal in case of DI signal. Quote Link to comment Share on other sites More sharing options...
