Sign in to follow this
Berry_B
HX Stomp into the HX Effects - set it to line level?
My Stomp outputs into the HX Effects. Does anyone know if I should set the output level of the Stomp to Line or Instrument level? It’s noticeably louder in line level.
From the HX effects, it goes out as Line level to a DI box, then to the mixer board.
In this particular case it really doesn't matter so long as the HX Effects is set to match with its inputs in its global settings. A mismatch is where problems occur.
Thank you! I’ll check to make sure the HX FX has the input set to Line level as well. Didn’t think about that.
