kkwaks Posted December 30, 2013 Share Posted December 30, 2013 Hello, I bought used kb37 to record guitar, bass and vocal. I use macbook pro 2012 mid and OS version is 10.9.1(Mavericks), Garageband version is v10. But I have not record anything yet because of popup noise when I connect guitar via toneport kb37 on garageband. I installed latest software like monkeys, gearbox and pod farm2 and I changed audio input/output setup to toneport kb37. I can hear guitar sound on garageband but also can hear pop up noise to play and record. I'd like to solve this problem. Thanks. Quote Link to comment Share on other sites More sharing options...
icorra Posted February 15, 2014 Share Posted February 15, 2014 I have the same problem. 2 weeks ago all was fine. I don't understand what is happened. I don't remember any update. I've tried to reinstall mavericks, garage band, the driver 7.3.6 without success. Also when i'm using garage I cannot change the sample rate. Only 44.1 is accepted Vice versa when i'm using gearbox or pod farm all work fine Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 15, 2014 Share Posted February 15, 2014 If you purchased a Toneport, you can use Pod Farm 1.12 for free. Make sure you are using Pod Farm 1.12 and not 2.5 Quote Link to comment Share on other sites More sharing options...
