chrismkane
External switch with the HX Effect
Hey good people,
  I have a couple different levels on my pedalboard and it is easier for me to control things from my lower tier. I have the HX effects that I would like to control any of the 9 blocks from the Signal chain to my NUX 2 switch, latching expression pedal.I am able to use it with my HX stomp. But the only thing I can get close to getting it to work with the HX effects is for amp channel switching.
has anyone ever successfully used a non-midi external pedal to control an effect block from the HX effect? As a bypass setting...
Chris
I don't think you can bypass effects on the HXFX from another device without using MIDI.
If that's not what you're asking, you might want to try rephrasing your question, be a little more exact about what you're try to do, because I sure can't make heads or tails of it.
I thought I was specific? LOL go figure.
It’s what you answered I want to be able to bypass the effect or turn it back on when I want to. And like I stated above I figured midi was the only way I could do it.  But I was hoping that was not the case.
Thanks for your reply.
Sometimes a guess is as good as a wink to a dead horse!
For 10,000 Galactic Credits, which album title is that a play on?
Hint: Happens when you make Humble Pie.....
