HX Stomp and Focusrite 2i4
medieval21
Hello.I am trying to connect HX Stomp to my Focusrite 2i4 interface and listen through the monitors connected to the interface but there is no sound at all.I connect my guitar to Stomp's input (instr level) and the Stomp's output (line level) is connected to interface's input (line level).What am i doing wrong?I know i can use Stomp as an interface as well but i don't want to disconnect the monitors from the Scarlett.The interface shows that it receives signal (the gain knob lights green) but there is no sound at all from the monitors.Thanks in advance.
1 hour ago, bogdancapitanoiu said:
use the Scarlett software (to assign Line Input to Monitor Output).
You can also see there the signal, or direct to the Headset output.
Save to hardware after setup to have it working without the software opened.
Which software?I only installed the driver and nothing else.There is a plugin bundle as well but nothing else.If you mean Focusrite Control,it is not compatible with 2i4.
