clemensg Posted January 2, 2014 Share Posted January 2, 2014 Hi, Had to get a faster computer, bought one with Windows 8. Installed latest Pod Farm (2.5.6) and now I can't get hardly any of my favorite effects, amps etc. In version 2.0 I was able to get a ton of presets, apms, effects and so forth, and now it is a pretty slim selection. Even when selecting from the drop down menu to get presets, most of them fail to load. Error Code 800a002. I"ve even tried to install the tones from a backup, but I still get the same error. Is there a solution for this , or is this the new Pod Farm? CG Quote Link to comment Share on other sites More sharing options...
k21t3ng Posted January 2, 2014 Share Posted January 2, 2014 I've got the same problem I've just gone from a windows pc, to a mackbook, and loads of my amps and equipment has gone to ,so if I get any replies that solve the problem I'll let you know ,cheers Paul Quote Link to comment Share on other sites More sharing options...
clemensg Posted January 2, 2014 Author Share Posted January 2, 2014 That would be nice, thanks. Just for info purposes the error code is actually 8000a002. Slightly different from what I posted above. In case it matters if a line 6 guru would care to look into this... Quote Link to comment Share on other sites More sharing options...
clemensg Posted January 4, 2014 Author Share Posted January 4, 2014 During the last couple of days I spent at least an hour or so to figure out how to get the tones I was looking for with the limited choices, like 3 amps, hardly any presets etc, and today while playing I noticed : Everything is back to normal. Got all the presets and equipment back. What's up??? Quote Link to comment Share on other sites More sharing options...
gzboy Posted January 11, 2014 Share Posted January 11, 2014 same problem with me, could you please let me know as well if you find the solution? thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 11, 2014 Share Posted January 11, 2014 Have you run the Line 6 License Manager to authorize your computer? If not you may only be able to use Pod Farm in demo mode, which severely restricts the available number of amps and FX. Quote Link to comment Share on other sites More sharing options...
brianbarauskas1 Posted February 16, 2016 Share Posted February 16, 2016 I have this problem as well. I have run the license manager and it still only has a few amps and effects. Any solutions? Quote Link to comment Share on other sites More sharing options...
tayjrock Posted January 4, 2017 Share Posted January 4, 2017 I had the same problem when transferring to a new PC. I fixed it and had all my custom tones I had saved working properly by updating all the drivers and hardware bug fixes using the Line 6 Monkey program. The program wouldn't update the first time within the actual program, but using the Line 6 website downloads the Monkey program provides, I was able to get the updates installed. Hope this works for you! Quote Link to comment Share on other sites More sharing options...
wabwas Posted August 25, 2017 Share Posted August 25, 2017 Any news how to fix this? I lost all the factory model.. Only shows default. Quote Link to comment Share on other sites More sharing options...
