[SOLVED] Switch between Exp 1 & Exp 2 with a different switch
hillbilly57
Switching between the onboard Exp 1 and Exp 2 using the pedal's toe switch always maxes the pedal position. For example, if I have Volume on 1 and Delay Mix on 2, delay mix will always max as I switch back to volume. Is there a way to switch between onboard Exp 1 and Exp 2 using a different switch so that the pedal position is retained? I rarely use wah and I’m trying to avoid using another external pedal. Thanks!
