HX Stomp display error
redglass
I have had the same problem but it was solved reinstalling the fimware (using a newer version of the installer that came up a bit later, and also using a main USB port (avoiding any internal hub USB ports))
Never had the issue again, so I did not returned mine.
I had installed the last firmware before. The device was directly connected to my laptop, so no USB-hub inbetween.
Same issue, mine seems to be associates with pushing the button/knob over "save".  Pushing this button, as well as changing views, clears it.  Only occurs when editing blocks in view mode.   Uninstalled/reinstalled latest update, no change.  Submitted support ticket.
  • 1 year later...
