redglass
HX Stomp display error
unfortunately I recognized a display error (reproducable) at my HX Stomp.
I see a black square or line instead of the values in the left corner of the device.
Any idea why this happens?
Best, Bastian
If it continues after a reboot, you should open a support ticket.
Bad Robot!
Does not occur again after reboot this morning. But will send back. Do not trust in it anymore.
I have had the same problem but it was solved reinstalling the fimware (using a newer version of the installer that came up a bit later, and also using a main USB port (avoiding any internal hub USB ports))
Never had the issue again, so I did not returned mine.
I had installed the last firmware before. The device was directly connected to my laptop, so no USB-hub inbetween.
Same issue, mine seems to be associates with pushing the button/knob over "save".  Pushing this button, as well as changing views, clears it.  Only occurs when editing blocks in view mode.   Uninstalled/reinstalled latest update, no change.  Submitted support ticket.
