double post, sorry
cvpe913
Make sure you're not connected to a USB Hub. Usually, the front USB ports on a desktop are a hub, so connect to the ports on the back.
Make sure that HX Edit and the Helix are on the latest (2.71) version. If not, install the HX Edit file from L6 website. It installs everything you need. Backup the Helix FIRST, then install HX Edit, close HX Edit,  then run the Updater.
If you're connected to a good port and everything is updated, you should be good. If not, try re-installing HXEdit (to re-install the drivers).
If still no good, call support.
Hi rd2rk,
Thanks, that’s really good advice, but the trouble is I have already been down that path with the same poster asking the same things here:
https://line6.com/support/topic/47568-help-helix-lt-cant-be-seen-by-hx-edit-on-my-desktop/?tab=comments#comment-300139
This thing is cross threaded, and we are all going down the same rabbit hole! Plus this guy is already on a replacement LT.
CONFUSED!
I am, because in my original reply I quote his original post - that has now been edited and has a picture added.
i really don’t get it!
CONFUSED!
I thought it looked familiar. I didn't respond the first time because you'd already hit it.
We see the same questions over and over. It's pointless to tell them "search before you post", so we just answer them.
The worst is when the same guy doesn't get the answer he wants, so he posts the question again, as if different people will respond with the answer he wants?
Then we answer him again, 'cause who remembers who asked what.....
I don't get it either.
  • Thanks 2
5 hours ago, datacommando said:
Hi rd2rk,
CONFUSED!
sorry accidentally had a double post... Apologize for the confusion
  • Thanks 1
My apologies for the double post
