Sign in to follow this
sdahe
Using my amps return
Hello,
Can I use the HX Stomp's amp simulation with my amp if I go from the HX Stomp out to the effects return of the amp?... Im bypassing the amps preamp if I connect the pedal to the effect loops return right?...
7 minutes ago, sdahe said:
Hello,
Yes, you are bypassing the preamp of your real amp.
I'd skip the Stomp's amp simulations. Try the Stomp's pre-amp simulations first.
