Setting minimum volume on FBV ShortBd Mk II
New to this forum, hopefully not asking a dumb question...
I like to use the volume pedal to punch up the volume for solos, and then back it down for rhthym playing.  Getting to a certain lower volume on the fly, while singing and playing is a bit hard to do, so it would be nice of the low volume could be set, say at 60% of full volume, while still having full volume at 100%, without mucking up the function of the wah.
Is there a way to do it?  I've resorted to taping a block under the pedal so it won't turn all the way off.  Natch the wah doesn't work very well that way....
Thanks for any ideas!
Brendan
What are you using it with?
I have one of these boards that I use with a Amplifi 30 and an Amplifi 150. In this case, the volume pedal parameters are a function of the presets. (which are setup in the Amplifi remote app)  I have several presets that are configured exactly as you've described, providing a reduced volume with the heel down, and 100% with the toe down.
