rickyjedai Posted July 9, 2019 Share Posted July 9, 2019 Hello.. I recently purchased HX Stomp and plugging in to Focusrite 2i2 >then to my monitors but it sounds thin and if turn up the gain on Focusrite it will clips. I tried to mess with HX stomp output and gain settings but not found a sweet spot. I tried to go direct from HX Stomp to my monitors and it sounds really good. Is there any settings or ways to fix this? I know I can use HX stomp as an audio interface, but sometimes I record with my singer and I dont want to switch out between Focusrite and HX stomp everytime. Quote Link to comment Share on other sites More sharing options...
brucegill Posted July 9, 2019 Share Posted July 9, 2019 Hey. First thing I’d do is adjust the Stomps Vol knob settings so it only effects headphones, (Global settings - Ins/Outs - volume controls). Then Helix will be at unity. Then check your helix output is set to line. Then set focusrite to line to match above. That would be the best start to work our what’s wrong in my opinion. Hope it helps. I’ve got the same focusrite so can have a check later if your still having issues. Quote Link to comment Share on other sites More sharing options...
