lepioc Posted July 15, 2019 Share Posted July 15, 2019 Hello, With my band, we use since 1 year a M20D with 2 L3S + 2 L3T. Wen we use the L6 link, sometines, the sound cut and reappear. We use AES Cable to link the stagesources. The last show, we used the 2 mains out (analogic) and no problems .... Is anybody has the same probleme with Line 6 link ?? Sorry for my english, I am a french Guy. Quote Link to comment Share on other sites More sharing options...
flanger68 Posted July 15, 2019 Share Posted July 15, 2019 Hello, normally L6 Link works...in your case, let's hope in a faulty cable, or in a faulty input connector into one of the Stagesource speakers. Have the cables checked, make sure they snap firmly into the sockets, and maybe connect the speakers in a different order, so you are not using the same initial Stagesource in the chain. Else, it may be the M20d being faulty... 1 Quote Link to comment Share on other sites More sharing options...
lepioc Posted July 16, 2019 Author Share Posted July 16, 2019 Thank you for the reply. We will try ... I've read the master knob of stagesource should be at 12 o'clock. We use to set at 3 o'clock. We do wrong ? Is it a way to cut the sound ? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 16, 2019 Share Posted July 16, 2019 I don't think the master knob setting will cause any problem. I agree with flanger68. If it's not a cable or connection problem I think your M20d needs servicing. Quote Link to comment Share on other sites More sharing options...
