ROBALLUSUS
Hx stomp vocal recording
I ve been trying to use the stomp as my only audio interface, bought a dynamic mic with an XLR to jack  adapter, and found it sounds too weak, need to push the preamp and the out volume settings, and makes noises, buzzs...
Am I missing somethibg? Seen in this forum people who uses helix to record vocals,
Maybe the floor and hx models has better mic  preamps?
Maybe my cable is too long?
Thought stomp was the same as the other models but with the 6 blocks only capability...
I d be happy if I could avoid buying another Interface and survive only with dynamic mics
Thanks for your help.
Yeah I fiddled with it and never got it to work well. It seems it just doesn't have anything that amplifies the volume enough, or if you do get it loud enough it's not clean enough.
I kind of chalked it up to the floor unit having a key hardware difference, like some sort of mic preamp.
Any feedback from other users on here? Is it possible we're both just missing something?
The helix floor is the only one with a mic-preamp, wich is usually required to get a mic signal with enough volume and low noise.
I don't own the stomp and don't know if there is a workaround, but it isn't surprising that it doesnt work
"Impedance converters" are simply reversed trasformer DI boxes. You can get 20dB of boost but this is not enough unless you capture a close gun shots with dynamic mike ;). Mic pres usually have about 20-60dB range.
  • Thanks 1
Two years later... This fellow shows how to do it. He creates a patch that simultaneously handles guitar from input L and mic from input R at the same time, but obviously if you want to record vocals separately it would be simpler to create a separate vocal patch.
https://youtu.be/WRFVib5qXBU
