kimsharp
After HElix 2.80 Update my L3m's are silent
I updated my helix to 2.80. Now the two Line 6 L3M speakers connected via L6 Link aren't working.
Global settings are reset during the update, is it possible your output settings are not done properly?
I went back and checked the Volume knob. It was set to multi, I normally set it to only control the XLR output so when I feed the house I can control the level. Thanks, Xmacvicar.
Interesting. I am glad its working, however, if it was set to multi, this should have also controlled the signal over digital L6 Link, so that kind of doesn't make sense?
Scratching my head there haha
Good catch.  I find using Multi quiets my presets as I go 4CM at line level out to all then XLR is the only output the volume pot controls.
I scratched my head as well when I was setting up my 4CM for stage and XLR out to PA path.  I haven't delved into the reasoning but with 2.80.0 installed I am revisiting everything
I get what you're saying but it makes sense if the outputs your monitor was plugged into before the update were not controlled by the Volume knob.  When the volume knob does not control a set of outputs those outputs default to full volume (as if the volume knob were at max). So, depending on how a preset is gain staged it may no longer be loud enough if it is now going by the Volume knob.
