Firmware v2.00 Update Failing
roscoe5
I just tried to update my  Powercab 112+ to v2.0 through Line 6 Updater v1.17 and it failed with an error and some instructions to turn the Powercab off, connect the USB, and try again. The Powercab display was frozen showing "Select/Connect USB".  Updater would not see the Powercab again unless I restarted the computer.  I tried different USB ports, but no success.
I had just updated Helix to 2.80 with the same USB cable in the same computer port successfully on the first try.
Well, I didn't end up contacting support.  I was able to update successfully with my wife's laptop with only Line 6 updater installed.
Must be an issue with USB on my Alienware X51 R2.  Funny that my Helix 2.80 update went fine amd not the Powercab
