Makron
GAP between change snapshots Firmware 2.80
Yesterday, I will update my helix LT from firmware 2.71 to 2.80. All is fine, but now, I have gap between change snapshots in diferent signal chain (dirty in up, clean in down). My metod, change volume to -120 and end of the chain, for inactivate dirty or clean channel. Now in 2.80, this change is not in real time. (fade in or fade out to apply change, bug I think)
Please help. Thanks.
Same -- that's one of several bugs that caused me to downgrade to 2.71 after a gig with many "surprises" from my Helix Floor. But, hey, at least 2.71 works!
I Found my big lag time came from IR Select by snapshot.split 1one IR 2048 Block to  two IR 1024 Block and use on/off  switch can help.But  i can use only 2 IRs.
I found this problem too...and when I change 2 different IR in the same IR block  the change is very very slow
